help
jldrifter
Car: 1989 240sx coupe
i have a 89 240sx coupe i just replaced the head gasket and i put coolant in it and it came out the oil pan with out even turning on the car what would make this happen
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
by putting coolant in the oil filler. just humor lol.id say it was left over from before.did you drain your oil beforre this happened.if you didnt i would run a motor flush change oil then see if coolant still exists in the oil. if so then you did something wrong in the repair.
jldrifter
i did drain everything and i left the oil plug out to and when i put in the coolant it cam out the oil pan and i did everything right on the head gasket is there anything else that it could be
slyedog240sx
did you use rtv on the timing cover. if not that might be your problem.if that isnt it something was done wrong.
