nismofan14 »
https://forums.nicoclub.com/nismofan14-u3055.html
Mon May 26, 2003 6:30 am
ok, first the ecu is on the passenger side kick panel. you need to remove the ecu so you can get to the diagnostic screw on the side of the ecu(dont unplug anything, just twist it around till you can get to the screw.) Next, with the key turned to the ON postition, turn the screw clockwise till it stops, wait about 1 second and turn it back to its original position(counterclockwise). After doing this, watch the check engine light, count the number of times that it flashes and that is the malfunction code, it will flash slow for the first number and then faster for the secound number. After you read teh code, repeat the steps of turning the diagnostic screw to return the ecu to normal setting, Write the code down and post it in this thread and i will check it in my service manual for you.
If ya have any trouble the are several write ups in the FAQ page of 240sx.org
