pimpin, bad fuel level sending unit will not strand you, as you are not actually out of gas, just cuz the indicator says so.
when u filled up how many gallons did u put in?less than you should be putting in, if the tank was really that low right?
even a real bad maf, would not run the car dry that fast.
Fred...
