Kouks wrote:Alright, car wont start. Gonna check for spark now, its either that or ECu isnt giving signal to fire injectors. Fuel pump turns on, motor turns over, no start.
Throw some ideas at me, Im trying stuff out now.
Bad Ignitor, spark plugs,, coilpacks, check for all good grounds. ECU. thats all I can think of. CAS maybe.
If your ecu is priming your fuel pump, it's priming your injectors as they work hand in hand. Did you actually check for spark or spray some starter fluid to see if you can get some response? Once you've done that and still no-go, move the ignitors plug around to see if you can get a response. You need to determine which of the needed ingredients you're lacking (ie spark, fuel, ecu assistance). Do some of these things and get back to us.
Dee
