help
shadowracing
Car: 1990 nissan 240sx
what up everyone, ok ill get to the point i just got an s13 blacktop but there is a leak where the turbo bolts down to the exaust manifold. ive tried toghtening the bolts but still nothing. so now i dont know if i should replace the gasket myself or take it up to the sr20store. i want to know how hard it is to replace the gasket. my mechanical skills are about a 7 thankx
Mike Wazowski
Car: 1997 Nissan 240SX
7? What does that mean?
Do it yourself. It's not hard. Just time consuming.
Hijacker
Car: '92 240sx Convertible
'94 F-150
i guess 7 out of 10.
Anyways, it's an easy to replace gasket, it's just time consuming, as Mike said. You'll have to remove the turbo and exhaust manifold together as a unit. There are 4 nuts and studs holding the turbo to the exhaust mani, each nut being held in place by a lock tab. More than likely, you've blown the gasket out and you can get a new one for a Z32 300zx.
One extra note is when you're unbolting the manifold, start with the nuts on the far left and right and then work your way in. It'll avoid any distorting of the head. Reinstall working from the middle two outwards.
And a last thing, please search. This topic was discussed a few days ago, and has been discussed a million times in the past. And make your titles a bit more informative.
