distriniboy2002 wrote:I AM STUMPED RIGHT NOW I HAVE A Z32 PASSENGER SIDE T25 TURBO I TURNED THE COMPRESSOR HOUSING THROUGH REMOVING THE RING NOW I DONT THINK THE WASTEGATE GOING TO WORK BECACUSE THE MANIFOLD IS IN THE WAY OF THE HOT PIPE ELBOW WHAT TO DO?
The Z32 turbo is WAY to small to be using for starters. Granted, you'll have boost at idle...lol...but it is going to choke the crap out of the motor and it'll be nothing but a big heat pump for the air entering the motor.
But if you're going to keep it, May I suggest getting a couple of angle silicone couplers, that way you can turn the comp housing to allow the wastegate to fit and you may not need new piping. You can always just use some flexible rubber tubing. I did for awhile on my Skyline. The tubing just isn't good for alot of boost.
WD
