well i need to know if the ka24de head (duel overhead cam from a 94 240) will directly bolt to my 1990 block. i want to switch heads...i want the duel overhead instead of the single. now i know my 90 comes with the 2.4 ka24e and i just need to know if they are compatible and what major adjustments if any i might need to do during this head swap. do i need to adjust the ecu? will the newer head bolt directly on the air intake manifold and exuast manifold? please help!
It's a fun project not worth it IMO.it gives oyu either 11.1 or 11.7 compression doesn't it?Depend on what SOHC piston you got...I know there is 2 write-ups about it.Search I'm too tired,,,,falling out of my chair.Good luck if you do it.
