Help - Swapping in another KA
4felix20
Car: Emerald Blue S14
I'm gonna have to swap in another motor here soon and i've never done it before. do you guys have any good advice? the thing that scares me the most is wiring and vaccum lines! damn, there's so many and i don't remember where they all go!
also, are there any special tools needed other than cherry picker?
i think i should just take it to a shop. does anybody know a ballpark figure on how much it would cost for a shop to drop in another engine?
1 last question - is there anything special i need to do to drop a S13 DOHC into an S14?
sunnys14
Car: S14
its illegal to drop in a motor thats older than the year of the car.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
Strip the s13 ka down to the block/head and put all the s14 parts on it. then you will end up with better cams. Its not that hard to do. It helps to have a friend with a car lift. I took me 4 hours to remove my ka out of my s13 last night. Air tools and electric impacts speed up thing.
Siizzzoooo
I thought the good cams were only in the 91's....no?
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
nope just some serious mis-information
91-94, excluding a percentage of 94 motors, have 248/240 cams, all of them.
if you are worrying about vacuum lines, just make sure to take them off in such a way its impossible to mix them up. I know that sounds confusing, but a few lines have colored rings on them, so that helps (or you can make some of your own)
since you dont actually remove the wiring harness, you can just tuck it up by your windshield wipers. And when you put it back everything pretty much falls into place.
My first time pulling the motor, by myself took about six hours from start to finish. And about the same to put it back in.
4felix20
thanks for all the advice
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
ha, sorry but just incase anyone notices, and i just did, all my ridiculous cam talk has gotten to my head. i mean 240/248, i just have 248/240 on my mind because i promised i would do it soon, but have been sorting out a ridiculous transmission rattle on my automatic car
4felix20
thanks guys. i'm still not %100 sure i would be able to swap engines myself though. when i thinkn about it, it's easy. but once i get my hands in there, everything changes.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
actually i would have to say swapping engines is easier than say, doing a headgasket, which i've done five...
4felix20
cool, i guess i'm just gonna do it then. do you know if the S13 DOHC engine is compatible with S14 ECU...that's the last thing i'm worried about . i'm thinking they should be, but i'm not positive.
s14 2510's
once you put all the s14 parts on the s13 block it will be just the same as what you started out with.
4felix20
you're right, that would be good. i may have to go that route..thanks man.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
i'm sure you already figured this out, but the S14 one is pretty useless to you, so sell it
