Help!!! Swaping a s15 sr into a s14 that had a s13 sr.
Socalgal
Car: Your mothas
Ok, so my s14 came with a s13 sr20det. The sr took a s*** and I found a good deal on a s15 motor. The motor comes with a harness, ecu, pretty much everything but the trans, turbo kit, ac compressor, and powersteering pump. I know I can use my trans, an turbo kit and the seller assured me the other accossories would fit. So when I pulled my s13 motor I detached the power steering and ac compressor from the motor and zip tied it to the chassis because the ac is charged and the power steering worked great. I thought everything would just bolt back up but today I saw a pic of a s15 power steering pump and it looks different. Has anyone been threw anything like this so I know what to expect? Like will the brackets from the s13 motor line up with the mounting holes in the s15 block so I can just continue to use my s13 accossories? The motor is being shipped so I can't look as of yet. Also other the the cold pipe everything else should just line right up right? I'll be using my s13 trans, clutch, flywheel, and starter and the harness is pre-wired.
Any help would be very appreciated. I though all would be good but now I'm worried I may be kinda f***. Just need my car working right again.
