Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sun Jan 25, 2004 5:03 pm
check to make sure the spring is seated correctly on the mounts, and that you've installed the upper mount bushings and things correctly, many many people complain only to find that they didnt install things correctly.
I would reccomend double checking everything you did, and trouble shooting by determining exactly under what conditions the sound occurs(bumps, turns, left or right side only, cold weather, etc)-chet
