HELP!!! suspension problem
s14junkie
jus installed agx with sportlines springs, while driving i'm hearing this rattling sound, like a loose bolt, comming from both rear suspension where the mounts are, i checked both rear strut mounts, and the seem to be intact, the when push down on the car to see if i hear any noise and there is was, while pushing down, i notice that strut seem loose in the mounts. i literally tried lifting the car by the wheel well, then there is was the strut/shocks looks loose as in its not bolted on the strut mount. any suggestions to solve this problem??
i went to the shop and told the guy he says that it need "adjustment" and it will be fine, so unfortunately the guy who installed it wasn't there, so i'm goin to go 2morrow morning early, so he cud "adjust it"
so i want your opinions on what the problem really is
Meantime
Three easy things to check -
1) Did you torque down both of the rear nuts holding the mount assembly to the body (should be 12-15 lbs per, I believe)
2) Did you torque down the center nut threaded on the shock rod itself (don't remember exact torque for this one).
3) Did you install the AGX in the rear with the correct orientation - the bottom part that fastens to the hub is meant to go a certain way on the threaded stud (it tapers, the adjustment knob is meant to face inside, not outside).
s14junkie
i'm going to check, that center nut u r talking about, i notice that the washer that is there seem loose, and the bolt seem to be fastened correctly
s14junkie
got the problem fixed, that bastard put the washer thing that goes above the strut boot the wrong way
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
just out of curiostity how much did they charge you for the install?
~swave
s14junkie
$70.00
driftaholic
Car: '91 Nissan RM S13
i did the same thing when i installed mine. heh. damn washer
