Help!!! Sunroof Leaking!!
twofourzeroSX
Car: 91 sileighty
OK..i just went out to my car 5 minutes ago, oppened the door and saw water poaring frum my sunroof control......I am so pissed. This is the first week since i got it that i havent had the rust covered on my roof...and it rained like hell. Well it must be worse than i think..so i better repair it soon. Does anyone have any tips!???!!? PLEASE POST ASAP!:help
DGA
Car: Cars
Your sunroof has run off channels that route the water down the inside of the pillars if it leaks. I have a '91 coupe with a sun roof that is not 100% alligned. You can see that the water can get in there, but no internal leaks yet. I also live in the Pacific Northwest where it rains 80% of the time. If you are still leaking, you might want to check the run off channels and see if they are clogged.
twofourzeroSX
Car: 91 sileighty
thanx..im hopeing that its just the rust that is letting in the water
DGA
Car: Cars
Where do you have rust? Here on the west coast, rust is almost unheard of?
twofourzeroSX
Car: 91 sileighty
Im on the east coast..with it being a highway car and all the salt on the road, rust is common. My rust is near the back of the sunroof..but its comming off tommorow:cool: . Anyway..thanx for the post, it wasnt the rust that let water in, it was just what you thought..one of the drains was cloged. well actually the drain hose or w/e got kinked when i was doing the wireing for my foglights last week i must have kinked it when i pushed the wire up around the fuse pannel because its only clogged on that side, im fixing that soon too.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
My sunroof leaks too. Water pools in the handle housing. No amount or caulking has solved it. My drains are not clogged either :(
