Help!! Suggestion for G37x tuner
viclauyyc
Car: 2009 Infiniti G37X
Hello,
Just got my 09 G37x sedan a little upgrade, which include: Takeda Attack Cold Air Intakes, Tanabe Y-Pipe and Tanabe Medalion Touring Exhaust. It sound very good but just one tiny problem. The car is not going faster. In fact, I think it goes slower. Thus, I think I need to get a tuner to fix the problem. But I don't know which one is the best one for my G37x. Suggestion please!!! I will also get a high-flow Cat. Which I also need suggestion!
thank you so much
Vic
viclauyyc
Sorry guys, the tuner I mean is the device that replace the car computer.
arrow23
Car: 2008 Infiniti G37S Coupe
Stillen Gen 3 CAI, HFC's and Gnd Kit
ARK Grip CAT Back
Hotchkiss Sway Bars
Eibach Pro Kit
GT Spec FSTB
Uprev Tune
20 mm Wheel Spacers
Stillen Front Lip Spoiler
I would highly recommend you wait until you get the High Flow Cats installed, before you get a tune.
Also, I would not even consider replacing the ECU.
The best way is to go to a reputable Tuner (shop), with a Dyno, and get an UpRev Tune.
This will cost you about $600 ($300 for the software and $300 for the Dyno tune).
audtatious
If you look for a tune I'd suggest the UpRev
Poolman45
Car: 2010 Infiniti G 37 Journey Coupe, K&N Cold Air Intake, Motordyne Art test pipes, Invidia CB exhaust, Strut Bar, UpRev & dyno tuned by HP Performance
I just upgraded my 2010 g37 Journey coupe, I added a Mortordyne Art test pipe, Invidia Gemini cat back exhaust and I had K & N Cold air intake, I had the CEU tuned with Osiris Lic. w/UpRev. I am happy with the results but want more. I am located in Palm Beach County Florida so I went to the UpRev website and they had HP Logic located in Royal Palm Beach, FL. I had them do all of the work including reprograming the ECU & Dyno run. After everything was completed they suggested changing the K&N Typhoon Cold Air Intake and upgrade to the Takeda long tube Cold Air Intake which I plan on doing this week.
Once everything is complete I will retune & post the Dyno tests results with all of the upgrades listed.
