HELP sub for amp
code08red
I need a good sub that will go with a kicker 750.1I dont want to spend more then $200.
AppleBonker
code08red wrote:I need a good sub that will go with a kicker 750.1I dont want to spend more then $200.
What size are you looking for?
Slightly out of budget, these two are awesome!12 inch10 inch
The previous version of the same subs (cheaper but can still make use of that amp):12 inch10 inch
code08red
I dont care about the size...just want something that fits in the a/cs trunkWhat type of box would I need? Where can I find a decent priced box?Sorry so many questions!
AppleBonker
code08red wrote:I dont care about the size...just want something that fits in the a/cs trunkWhat type of box would I need? Where can I find a decent priced box?Sorry so many questions!
Any mobile A/V store should carry sub enclosures. They will probably also be able to custom build one (although that will obviously be more expensive). I think some people have used a box from eBay, so I'd check those possible options. Not too sure about pricing since I've always built all of mine. Maybe someone on here has more experience.
notaverage
Car: Altima Coupe 3.5 SE w/ tech pkg and VDC. Precision Grey
Here's the cheap box you're looking for. good terminals, good carpeting, generally good quality in my opinion. But the best of all is it fits snugly under the rear deck of the tiny A/C trunk.
iammai
Car: Altima coupe
Did you forget the link to the box? I'm assuming its the one on ebay.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
iammai wrote:Did you forget the link to the box? I'm assuming its the one on ebay.
i thionk he meant this...
http://cgi.ebay.com/ebaymotors...ZWDVW
prefab boxes are ok, but just be sure its within the space requirements for your subs...
subs operate VERY differently depending on what type of box they are in, and how much air they have in that box... this differs for every sub
rjdmmfl1
Apllebonker, those subs you recommended are dual 4 ohm subs, so he's gonna have to wire them down to 2 ohms... him amp pushes 750 watts at 2 ohms.. he may blow those subs
http://cgi.ebay.com/ebaymotors...l1116
This sub states 600 watts RMS, but will pound like all hell with 750 watts going to it and will definately hold up with that amount of power...
AppleBonker
I mentioned those intentionally. Keep the gains down so they don't see more than 600 watts and they'll rock. Extra headroom is always good. Won't drive the amp to clipping. But again, the gain setting is KEY!
rjdmmfl1
now you and I both know the average consumer is gonna crank that gain thinking its a bass boost... extra headroom is ALWAYS a good idea though...
I'm at odds about what to do with my system... As much as I would love another T2, I just don't want 120 lbs of subwoofer in my trunk... and I refuse to fork out $2000 for that UL12 and another $1000-$1500 for an amp that can push it
AppleBonker
But if the average consumer reads my gain setting tuturial in the FAQ, they should be ok.
Yeah, the UL is expensive, but you should never pay that much. I think the amp did run nearly 1100 though (new w/ warranty). We'll definitely have to meet up when your in Chi and I'll let you see what it sounds like.
rjdmmfl1
can't wait my dude
