help stupid question time
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
ok so i want to change out the springs and shocks on my 89 coupe, but i was wondering if i can use upper pillowball mounts when i switch over, or if those will only work with coilovers
and yeah i tried searchin and got nothin
thanks
j
naed240sx
Car: .....
Yes you can, but they have to be a specific type. I also think that they are only available for the front.
JeromeS13
Car: 2008 Subaru Impreza STI
Do you want those mounts to be able to adjust camber? If so, the easier route would be to get eccentric bolts for the spindle. They're a lot cheaper and offer a decent bit of adjustability when using lowering springs.
hybrid_flyer
naed240sx wrote:Yes you can, but they have to be a specific type. I also think that they are only available for the front.
Hmmm do you know what types will work?? and why they wont work with the rears?
JeromeS13 wrote:Do you want those mounts to be able to adjust camber? If so, the easier route would be to get eccentric bolts for the spindle. They're a lot cheaper and offer a decent bit of adjustability when using lowering springs.
so, where can i get the eccentric bolts??? So they should be able to give enough adjustment to zero the camber with aprox. a little over an inch in drop?
thanks for the info guys
nismofly
Car: 89 Nissan 240SX Hatch
why would you zero the camber? stock camber is around -1 or so in the front already
naed240sx
Car: .....
Yeah, don't run zero camber.
If you are only gonna have 1-2 inch drop, there is no need for front pillowball mounts.
