Help Strut tower lean, tire leaning inward
omidbahreini
Car: 1990 300zx tt
Hi all, need help, the top of my strut is ripping away at the top and causing the drivers side front tire to lean inward. How do I fix this, and prevent it from happening again, thanks in advance
rgregoryb
Car: 1992 300ZX 2+2 NA
Photos?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Uh, put the car on a frame rack and have it pulled back into place and re welded, this isn't something that should be happening unless that car has been in a wreck. Now of the problem is just camber a bad upper control arm balljoint is the likely issue, replace the upper control arm, and possible go to an aftermarket unit wiht adjustable camber.
DCaff300ZX
Car: .
1993 CRP TT- Modified
evildky wrote:Uh, put the car on a frame rack and have it pulled back into place and re welded, this isn't something that should be happening unless that car has been in a wreck. Now of the problem is just camber a bad upper control arm balljoint is the likely issue, replace the upper control arm, and possible go to an aftermarket unit wiht adjustable camber.
Agreed, hard to imagine the shock tower mounting point having ripped in any way and the car drives...most likely the common totally worn out upper control arm causing excessive movement and camber, and worn tires. Be aware that amount of wear will mean other items are probably also worn excessively, such as tension rods and coil springs (which both can also cause excessive camber/tire wear) which are all very common to our old cars. So a trip to the tire shop for suspension work or if DIY-able, a call to Powertrix or other coilover source for a suspension overhaul seems to be in your very near future.
The most likely parts you will need FYI are new shocks installed with new springs (or if wanting/able to afford an upgraded and simpler system, a one piece coilover system), new upper control arms and tension rods, and rear upper control arms. There may be more depending upon the overall maintenance level of your Z32.
BTW, I see that Charles at Powertrix still has a few sets of group buy-priced coilovers left (Powertrix post in general section)...BEST thing you could do for your Z32, and you also learn a LOT about your suspension talking to Charles, and he will do that I promise. Call him!
Good luck!
