help still oveheating after new thermostat.?
topairhead
Car: 180sx
ok heres the problem i just installed a new thermostatin my DOHC when my temp. indicator goes alomost to high im guessing the thermostat lets coolant in the engine. i can feel the hose pretty warm the (bottom hose).the one that goes into the thermostat.now the weird part is when i slow down the temp goes up but then out of no were the temp goes down its keeps on doing this back in forth.and of course when i accelerate it stays at proper temp.any ideas anybody thanks?
KASilvia90
Car: 1990 Nissan 240SX KA24E M/T
Are you sure you got the t-stat in correctly? Could be a bad gauge also. The way a t-stat works is simple, Coolant sits in the block until it gets up to temp. The t-stat has a wax material around a spring, when the coolant gets warm enough (oem is around 175degres) itll soften the wax and cause the spring to open up, allowing coolant in through the lower hose, into the radiator and cycles to the upper and in that pattern.
Things to check, air pockets. Did you bleed the system when you finished? Crack there should be a screw somewhere around where the upperhose connect the the engine, when the engine is cold open that competely and fill the radiator until liquid comes out, then close it back up. then start the car (best to lift the front about a foot to make the cap the highest point) and let it get up to temp with the cap off and kinda jiggle hoses around. If the coolant keeps splattering violently and more so on a rev once its warmed up (like bubbley for 30minutes straight) you might have a blown-hg.
topairhead
Car: 180sx
yeah i put a gasket and high temp silicone and everything was in place. ok well i did not bleed the system and i havnet raised the car to a hight point so they wont be no bubles but good thing im about to do all of this 2morow to see wat comes up thaks alot ill keep u posted to see wat happend by the way wats a "hg"?
irocknrol2
Car: 1991 240sx Hatch/1993 240sx Coupe
[QUOTE=by the way wats a "hg"?[/QUOTE]
Head Gasket
topairhead
Car: 180sx
oh ok well it cant be that cuz i just put a new one suround with high temp silicone.but ima try bleed the system hope it dont go all crazy
vancouverbc
Car: 1991 240sx
make sure the interior heater is set to high and you warm up the car so air in the heater area has a chance to escape. Someone else also mentioned bouncing the entire car to shake air loose ie sit on bumper. I have put 6 litres of coolant in my car so far. .5 liter in the reservoir. the total is 7.25 quarts if you dont like metric.
topairhead
Car: 180sx
vancouverbc wrote:make sure the interior heater is set to high and you warm up the car so air in the heater area has a chance to escape. Someone else also mentioned bouncing the entire car to shake air loose ie sit on bumper. I have put 6 litres of coolant in my car so far. .5 liter in the reservoir. the total is 7.25 quarts if you dont like metric.
ok i arlready set the heater on on high and bleed the system alot of air came out. then i was test driving it and the same problem happedn the temp goes up and when it reaches high the temp just drops down fast. another thing the radiador gets really hot and the coolant runs up the reserve tank and spills everything. i also changed the raditor cap.could it be that the cap is not good?
180fan
Car: 89 fastback
It's possible that the cap has gone bad, when was the last time you replaced it? If you haven't replaced it yet, it's something that's 1. cheap to replace, and 2. a good idea to replace and lastly 3. could be the culprit to your boiling over problem.
irocknrol2
Sounds like you have a leak somewhere in your system. It may be a small one that takes some searching to find.
topairhead
Car: 180sx
yes i changed the radiator cap , but im thinking in returning it and getting a better one.as far i know the colant is leaking from the reverse tank due to boilingand my reserve tank is broke also too.and i cant find any other leak in my system....?
bige240
Keep trying to bleed the air out of the system...doing it once may not be enough, heat the car up to temp and let it cool down, fill up the radiator. keep doing it until you don't have to put anymore coolant in...
topairhead
Car: 180sx
alright thanks but one problem i cant even start my car anymore i turn the key on and it seems its about to turn on but it doestnim so sad now.
