Luderacer14 »
https://forums.nicoclub.com/luderacer14-u24944.html
Fri May 13, 2005 2:08 pm
Ok, I replaced my clutch and flywheel the other day because my clutch won't disengage when I step on the pedal, I put everything in, it worked for 5 miles and did the same thing again!!! It won't go in gear when I step on the clutch at all!! It will go in when the car is off. Now the clutch pedal feels like it's losing pressure again. I replaced my slave and the master still pumps. But when I pump it hard, than stop, the fluid looks like it goes back up. When I took the transmission off, the throwout bearing was still hooked on to the fork, everything inside looked fine, I have no clue, plz help!!!!!!!!!!!!!!!!!!!!!!!!!!!
