Help...stereo installed... now heated seat and awd wont light up
bigballerhanh
Car: 2001 nissan pathfinder
I was installing a new headunit and sirius today and of course i had to take the front panel off and disconnect a bunch of things such as: clock, hazard lights, heated seats, awd/4x4 etc... After installing the headunit and craming all the wires inside the small area behind the headunit, i put everything back together and now the driver side heated seat button wont light up and when I select all wheel drive that wont light up on the dash board. However, if i select 4hi or 4lo that lights up perfectly. If anyone has any suggestion to fix this problem I would really appreciate the help....thanks
volp
Car: 99 Infiniti QX4
I just installed siruis today too. Good investment. Are you a hundred percent sure you put the wires back in the exact same spots they came from, and a hundred percent sure you didn't accidentally break a wire out from one of the clips when you pushed them all back in?
bigballerhanh
I am not exactly sure but because i was getting dark but i will double check everything for sure tomorrow when i can get some more daylight..... Anything specific i should check for???
volp
just look and see if any of the wires came free from the harnesses. That and you didn't mix up any of them, but I don't think you can because if I remember correctly they are all different.
coastal6.0
Car: 08 pathfinder se v8, 06 f250 powerstroke
swap the seat and 4x4 plug, they might just be reversed. nissan uses alot of plugs that are the same shape.
bigballerhanh
I got the 4x4 issue fixed. It was a bent pin inside of the plastic harness. As far as the heated seat light not lighting, I dont have a clue. The seat heats up though!
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
If the seat warms your buns but the light doesn't come on, a look at the FSMindicates it's just about got to be the bulb. Either loose or burned out.
Chuck
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
must be the light, if your going to replace it good luck..the bulb is the wierdest and tiniest incandescent ever, and i broke my harness clip getting it out so now the switch doesnt work,..gotta replace it
bmlawless
Car: 1999 Infinity QX4
That's funny. The light for my driver's side seat stopped working after I pulled the dash also. I checked the bulb and it's blown. It is an odd little light so I just left it alone.
bigballerhanh
Thanks a million guys.... If you all ever find any info on replacing that heated seat light, let me know..... it's really annoying to me
bmlawless
me too
