help starters dead!
ser chicken
Car: cars, water and writing
okay... heres the deal, my cars (91 Sentra SE-R) not cranking... im getting power at the coil side of the relay (so the ignition switch is fine), and the clutch saftey switch is functioning properly and getting current, but im not getting 12 volt at the relay (switch/starter side). the fuses are all good (best as i can tell). i dont have my manual on me tonight, im getting it back in a few hours so i havent been able to look at a wiring diagram. i was just wondering if anyone had any ideasmy battery is also fine, and theres no load at all on the electrical system when trying to crank.im suspecting a bad connection somewhere right now.please... any suggestions are greatly welcomed.thank you-Pete (f***ed) S.
tonynalli
try tapping on the starter. the solenoid might be stuck
NISTECH
tony look at the post dates before you reply. good info you gave but it was almost 2 years ago that post was put up.
