flicker »
https://forums.nicoclub.com/flicker-u89253.html
Wed Feb 13, 2008 10:04 pm
Okay, here's the deal so far, bought the swap complete from a trusted import company. Motor and transmission were not seperated and the swap was installed. Went to start the car, and the starter turns over fine, but just sounds like the flat surface of the starter gear is just rubbing on the flat surface of the flywheel. No grinding noises, just a rubbing/whirring sound. I now have 4 SR starters that all do the same identical thing.
The motor turns over fine by hand, the flywheel shows NO visible signs of wear, the only thing I can think of right now is possibly the wrong flywheel is on the motor, but I don't know if there is any other flywheel of a different size that will bolt to the motor with the clutch that fits the transmission.
