HELP!!!!Starter Wont Engage Flywheel
sdgills
I have 93 Nissan pickup 2wheel drive...The truck was as automatic but i change over to a 5 speed....I have change everything and even got a new starter.. But for some reason the stater just wont engage the flywheel.. I use two different flywheels and the same thing...I been working on this a whole week just cant found out whats the problem...So if anybody could help me out I THANKS ALOT...
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Need more info. Is the starter bad?
dvdswan
did you get a starter for an auto or manual?
sdgills
I got a brand new starter from auto zone ....I got it for a manual...I ever tryed the old one that was with the automatic transmission ..
Rev_D21
Autozone is your first problem. Can you tell us more about how it doesn't engage the flywheel? Is the solenoid working properly if power is applied? It's a tooth count issue? Is it a fitment issue? Are the teeth just grinding against the flywheel? Need more info. Pics or vid would be great as well.
sdgills
I got the problem solve today ...The starter I got from autozone wasnt engage far enother to reach the flywheel...I got a used one from the junk yard and the truck fired rite up ...Went to autozone to take the starter back for a refund but they said they couldnt cause the starter was working... So thanks to all that help me...I really Thanks alot..
longtooth
Car: 89 d21 HB
sdgills wrote:I got the problem solve today ...The starter I got from autozone wasnt engage far enother to reach the flywheel...I got a used one from the junk yard and the truck fired rite up ...Went to autozone to take the starter back for a refund but they said they couldnt cause the starter was working... So thanks to all that help me...I really Thanks alot..
Thats a bad store. I never had a problem with any of my returns with Autozone.
Rev_D21
Yeh, that's a pretty bad Autozone. Time to start looking for a new parts supplier.
