atticus »
https://forums.nicoclub.com/atticus-u20762.html
Mon May 23, 2005 7:02 pm
I have tried to search for this topic but I found nothing. Any help you guys can give me would be great. I have a 92 240 coupe with a Q's front end. I have just finished installing a what I think to be a red top. It does however have the fiins on the front of the head like a (s13) black top does. Anyway here is my problem: The car runs and idles fine, however when I give it full throttle and it hits full boost it begins to break up really bad. I did all the wiring myself, checked the CAS, changed plugs, checked timing, changed MAFS, checked for boost leaks. Can anyone give me some ideas as to what else I need to check for? I was actually thinking about changing the injector o-rings next what do you guys think? Thanks.
