Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Oct 03, 2006 5:04 am
So let me get this straight. You're car isn't doing ANYTHING when you turn the key? The starter isn't trying to turn the motor over? If all you're hearing is a loud audible click when you turn the key to the start position, it's probably a bad starter. You'll usually hear the starter relay click once as it supplies power to the starter motor.
Now, if the starter is engaging, but the motor doesn't run, then you need to look at the three basic things needed for combustion. Air. Fuel. Spark.
Unless a kitten got stuck in your intake piping somewhere, I'll assume you have air going into the cylinder. You've stated you can hear your fuel pump turning on, but have you checked to see if fuel has made it into the cylinders? Pull a spark plug and sniff it for gasoline odor. If it has a smell to it, then you have fuel. Of course this is a simple test, and I would prefer it if a proper fuel pressure test was done, but you may not have access to a gauge you can throw inline.
Next is spark. This could be as simple as a dead ignitor chip, or as complicated as a cut wire somewhere. Double check to make sure all grounding wires have been grounded out. The coil packs are odd creatures. They don't like to work if you're missing even just one ground. One you have all the grounds connected, try to find a spare ignitor (from a friend possibly) Even an ignitor out of an old Pulsar will work. Try swapping ECUs out if you can find a spare or someone willing to help you trouble shoot.
Lastly, this is an odd question, but i've seen this happen a half dozen times. Did you pull the Crank Angle Sensor out at any point in time? If so, I've seen that be the cause of a motor that refuses to start. It even happened to me. The S14 service manual has you set the CAS at 180 degrees off (apparently the S13 requries TDC of the exhaust stroke, not the compression stroke like the S14 does). What this does is fire the spark plugs when the valves are open and there is no compression in the cylinder. The tell tale sign of this is a popping noise coming from your intake. Anyways, I know this is a lot, and sounds confusing, but it should help you get on the right track to getting your motor started.
