hi guys, i ran another compression test on my sr
170-180-180-180
when i put the spark plugs back in, cylinder# 1, when i put the coil plug back in, it wouldnt go all the way down. at first i thought i didnt screw it in properly. i tried another spark plus just to see if the original spark plug was threaded, wasnt that either, same thing happened with that plug.
i found out that the thread (that the spark plug screws into) has popped up.
how bad is this?
will i have to take off the valvetrain to get it??
has this effected or have anything to do with the piston/rings/valves/cylinder walls??
thanks, any information would be greatly appreciated.Jd
