Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Jun 18, 2004 6:22 am
the only way to fix a blow off valve richening the fuel mixture is to recirculate it. It's just the physics of a MAF equipped system. The MAF has already metered the air and the fuel is sent to the injectors. When you close the throttle plate and the BOV vents, the air leaves the system completely, but the fuel still reaches the cylinder.
BOV's don't stall the car out all the time, but it is a common problem for a car to be driving along, and then when you come up to a stoplight, stall out.
