Alrighty, Hey guys I'm harvey, I just recently acquired an s13 hatch w an sr20det. This was my friends old car and I see now why he sold it lol.
Anyone the car has an intermittent spitting/sputtering/breaking up. Problem. now we don't really know what happened but it started to spit more and more as time went on, I really wasn't around the car much when he had it but this what I know.
It has a brand new wiring harness in it, 1 1/2 yr old rebuilt t25, fmic, ebay ssqv bov, everything else is stooock.
When I got the car the car was sputtering hard under boost, approx 5lbs is would just die out and any throttle it would just spit. I looked at the plugs they were waaaayyy off, some junk 5 heat range, I put some used greddy 7's I pulled off a jdm s14 sr20 long block I had at work, put em in with a .035 gap. same problem, talked to someone they told me before EVO coils go bad they have the syptom he told me to try changing the gap to .025.Did that and the car ran greeaaaaaaat, full stock boost all the way to 7500rpm, few days later on the 1/2 way to work (40 min commute) it stared to spit under cruise soo bad it wouldnt go at all, any time I gave it throttle it just wouldnt go. I pull over, check codes I find a TPS code. Removed B+ for a couple minutes then started up ran fine, this repeated itself every 10 minutes. Checked the TPS the #'s were all off from spec, looked at the plugs they were red, yes red and white. got new plugs, gapped em no change. Ran okay but still spat under boost. also it would die out like before when I had to pull over but a trick i found is that if I turn the car off and then turn it back on it goes away immediatly. wtf?
Got a new TPS, checked #'s. It's okay. put it on same issue for about a week. Only now, it's intermittent, it will sometimes fix itself and run fine...not really fine it'll still break up but very slightly, but it will go to redline full throttle. Some one else told me to try A fuel pump, I threw a walbro in there, no change. Again I tried another person, they were looking at the suction pipe and suggested it may be collapsing so I took it out and put a 90 degree alum pipe in it and while I was there I noticed the air filter was dirty so I changed it with a new clean one, and guess what. IT RAN GREAT, incredible. but now it wouldnt idle, really rough. I looked at the plugs, black. now its running rich??, this was in the morning and I parked it while I worked, then on the way home about 3/4 it started todie out like before.
I am out of ideas. I'm wondering if anyone has had a similar issue or has any insight.
this is whats been done so far so Im assuming we can eliminate this
HarnessSpark plugs/GapFuel pump (walbro)TPSFPRfuel psi ok. 40ish no change when spittin.
any help appreciated, im pulling my hair out with this, it's prolly something stupid and i'm overlooking like always.
thanks.
