HELP SR injectors wont pluse.
lazymofo
i got a s13 with a Sr blacktop.. i got the car running with a E MAFS. i was planning to drop a Z32 MAFS, which i did. after i spliced up the wires then turn the motor over, it idled about for a min. then it spubders then die. it wont turned back on again., i redid the harness. then still got nothing... check spark, good. check fuel presure, good. then i looked at the pulse. consant power no pulse.. whats going on here. i think i ****ed up the wiring for the Z32 MAFS, then it causes a sensor to went out.
please help
stan
S13FASTBACKSR
Car: '92 Fastback SR powered
so when you had the z32 maf wired and then you re-wired it..did you change the wires around or just reconnect them for a better connection? if you changed them around then definately shorted out your ecu because if the wires arent right thats what happens..so obviously if you wired it two different ways you shorted it out and its time for a new ecu
lazymofo
S13FASTBACKSR wrote:so when you had the z32 maf wired and then you re-wired it..did you change the wires around or just reconnect them for a better connection? if you changed them around then definately shorted out your ecu because if the wires arent right thats what happens..so obviously if you wired it two different ways you shorted it out and its time for a new ecu
man i was really not hoping anyone would say that.. i was really thinkin about it too... the car ran for a lil bit then its spudders then died...
S13FASTBACKSR
ya bro you def. shorted out your ecu..if you have aim drop in your sn or just email me at [email protected] for a diagram i have of how to wire the z32 maf
