HELP!!! SPUTTERING.....INJECTORS?
chrismo240sx
Car: 92 240sx HB
S13 Blacktop
Hey i have a 93 240sx with 107,000 miles and just recently my car started sputtering randomly when i was driving home from work. Its weird...the car does this only when the engine is warmed up and if i give it more than about half throttle. When the engine is cold i can floor it and its fine and if the engine is warm i can only give it about half throttle before it starts like mis firing or sputtering. Does anyone know what this could be...i was thinking maybe the injectors but not sure....any help would be good thanks.
Dorifto12
Car: 1990 240sx
Check ground cables,i had the same problem and i cleaned out my flowmeter and changed my ground and it went away,still does it sometimes tho.(was much worse than it is now)
also check if you have a leaky injector.
NotDave
Car: 96 240sx that needs paint
put an ohm meter to the injectors...should read ~11
seanman
Car: 1989 Nissan 240sx
or you hook up the ohm meter? posy to battery and neg to injector?
NotDave wrote:put an ohm meter to the injectors...should read ~11
silvia2slow
Car: 1990 Nissan 240sx
what about coolant temp sensor?? my car was doing the same thing (more of a jerking than sputtering) and i thought it was the injectors due to bad gas mileage and me smelling gas all the time. changed out that sensor and it went away.
neverlift
if it starts clearing around 4000rpm its most likely the cts
BUILT S13
Car: Nissan 240sx
I just had this problem a couple days ago. I did a tune up changed the fuel filter and cleaned the injectors and the problem was fixed. does it only have problems when you take off, or all the time. My s13 was havin problems takin off, and now that the injectores are clean, it runs great.
Change fuel filter and clean injectors, you should be fine after that.
