-=BoYo=- wrote:And what usually goes first to make a 300 run ruff, i was thinking injectors, and if so how do you check the injectors…???
Injectors are the most common culprit. They loose their electrical resistance, there's several theories on why.
To test them, remove the harness and use a multimeter to ohm test for resistance. If they test above 14 or below 11, they are toast. Another common problem is corrosion on the harness connectors, clean them while they are removed to test the injectors.
Tim
