Nils wrote:You are not sure where/what the turbo is?this will be pretty hard to diagnose if you dont even have basic engine/turbo knowledge.
What kind of fan(s) are you running? do you have a fan shroud?s13 sr in a s14 chassis? How long have you had this sr20det? etc.....n
I am learning as I go along I just took over my brothers 240 cuz he went off to collage. The sr is an S13 in a S13 chassis I have an electric fan (not aftermarket) and the stock shroud
Nils wrote:Exactly how hard did you drive your car that day, how hot was it outside? How long?n
I drove it up a street reving to 6000 through each gear once and my car began to overheat so I went home it was pretty warm out dont know the exact temperature.
Nils wrote:It is not uncommon for the exhaust housing to glow red after driving a turbo car hard for an extended amount of time.... I really hope you didnt just shut off the car after driving it hard. Turbo needs some 'cool off' driving to prevent from warping and cracking.
let us know...
n
No I did not shut it off the car was maintained on by the Turbo Timer for at least 3 min.
I am aware of turbo maintenance.
thanks for the reply hope the info helps, help me
