HELP! smoke from exhaust manifold
stumpz
alright here's how it goes: started car, oil pressure light stayed on...i heard a tick tick tick tick coming from the valve cover area..i was told to let the car to run for about 10 minutes...and it didn't overheat, i let it get up to normal temperature for a car..cut it off..noticed that either steam or smoke was coming from the heat shield at a decent pace. i got under the car and it looked to me as if it wasn't coming from the turbo..i couldn't see above the turbo or below the heat shield..please i need help...did i blow my turbo up? i need all the help/suggestions i can get!
stumpz
it's a little cold outside, but that shouldn't bve why it smoked for almost 5 minutes...
stumpz
also, my timing is a little off, it's not a steady idle, but it's a lot better than some of my friends idles..
stumpz
nvm it's just oil/dust burnoff and shizzle..but i still have the lifter tick :( more money out of mah pocket w00p w00p!
quiksilvia
Car: 95 s14 se
not really, u need to bleed the lifters, u can do it with a paper clip and a ziploc bag of oil, get me on aim if u want to do it urself, its hella easy
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
I used a cup of oil and a paperclip. Just put it in there standing fully upright and keep pushing the paperclip all the way in, and then pull it all the way back out until you no longer see any bubbles leave from it.
stumpz
aiight thx a lot guys, i'll get at you tomorrow quik
robbbby
Anyone have like a alitle write up with a couple picture on how to bleed the lifters properly?
