Dur.szhosain wrote:
Engine oil and ATF are entirely different colors at least (also smell). If it is ATF, it will be red ... (not like engine oil at all. So you can check that relatively easily, I'd think.
Z
I'm aware of this. However, any time that I've checked the ground, I can't really get a suitable amount from the porous asphalt to transfer to my digit to check.
Both fluids check in at the correct levels. I've checked the ATF hot and cold and the motor oil hot and cold as well. In the driveway and the parking lot. Right on the street as well.
