HELP! Silvia front end wiring!
Moody
Car: stuff
I swapped the Silvia front end onto my vert, and I wired up the headlights, but I've done something wrong, because I have no turn signals! Are there any write ups on how to wire in the headlights or anyone that has wired them up before so that they work?
nissan_s15_240sx
Car: '92 nissan 240sx with s15 silvia front end conversion
Oh yeah, what model silvia did you do?I did a s15 silvia front end conversion on my '92 240sx fastback. Well anyway I just went and looked on my car to double check on what wires go to what and here's how they go
driver side head lights/turn signals.
highs (red with a blue stripe)lowes(red with a white stripe)turn signal driver side ((+) green with a black stripe (-) black)
passenger side head lights/turn signals.
highs (red with a blue stripe)lowes(red with a white stripe)turn signal passenger side ((+) green with a yellow stripe(-) black)
I hope this helps you.
Moody
Car: stuff
No one has any help!?!?!?
nissan_s15_240sx
I guess you dident't see the post I wrote befor so here it is again.
Moody
Car: stuff
I saw it, but that doesnt help me!
nissan_s15_240sx
What do you need then? I thought you needed toy know what wire is for what. Whats the problem and maybe I can help.
nismotune240
Car: s14, s13, rx7, swift
I just did this to my 95 but i have a 91 also i looked at it and would recommending that you splice the turn signalwires to your sotck harness and on the back of the silvia headlights there should be a green and black wire for the turn signals(they come out of the headlight and loop to a connector) you have to eliminate the connector and buy female and male connectors and splice them together and you should be making signals in no time.
raw0330
Car: 95 S14.5, 99 P11, 85 S12, F4i, F2, R1
I think, maybe he is asking if anyone knows where the female connector can be found to plug in to the 3-pin male connector that routs to the turn signal and marker bulbs. I've been wondering this same thing and haven't found anything, yet.
