evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Sep 26, 2008 6:08 am
if the car was runnign fine why did you add the lucas stuff?
so does it not accelerate even after warming up now? if so I'd suspectt he fuel pump, it's real easy to go get an inline fuel pressure gauge, get your idle reading, witht he vac off the FPR it should be like 40 psi, with the vac on the pressure should drop to like 34 ish, when you rev the engine the pressure shouldn't drop below
if it's not he fuel pump it might be the afm, the FSM details how to test for dead spots ont he afm, it could also be a distributor or ignitor problem but I suspect the FP or AFM
another simple item check the connection at the CHTS, these sometimes get knocked off and cause excess rich condition fouling plugs
but if it idles fine and won't rev that kinda points to the fp, generally it starts limiting boost then the level gets lower and lower till you just can't rev, although I have seem them fail only when hot as well
