kapower06 »
https://forums.nicoclub.com/kapower06-u18983.html
Wed Jan 25, 2006 6:52 pm
long post so get ready, I think I found my problem, Ok so when i intially started and ran my car my injector plugs were wrong 2 of them, and my knock senor wasn't hooked up. So I was dumping all kinds of fuel (at the wrong time) and pulling timing like crazy ( base timing was set at 10* btdc, now its 15 *) because the knock sensor was tripping the ecu. I also have the wastegate referencing from the comp. nipple. The boost was steady at only 5-6 psi. SO I hooked up the knock sensor put new plugs in, and cleared the codes. Went out for a drive. when I got into second I can take it to high rpm with low to mid throttle. Boost is 10-11psi. But when ever RPM climb to around 5k it just cuts out completely. No hesitation, no stumble, just a hard cut. Im wondering if a 3in. 02 housing and 3in. downpipe, no cat or muffler, it stops at the flange on the downpipe. Will this along with no fan clutch, no p/s, and no a/c plus the exhaust and HKS air filter, with the 10-11 psi on stock ca turbo with ARC smic., be enough to trip the fuel or boost cut,? replies tonight would be wonderful. Thanks -Jake
