supra brit »
https://forums.nicoclub.com/supra-brit-u17265.html
Mon Jul 18, 2005 7:33 pm
^ We did all of that...now what happened:
Found out there was just a bunch of bad gas in the lines, so we got some out, hooked it back up, and it started (w/ the dist. all the way advanced)...then we realized that there was a horrible noise coming from the motor - real bad chatter, sounding like valves or lifters. Then we realized that there was absolutely no oil under the valve cover at all...so the oil pump is not pumping...after all of the cranking and letting it run, shouldn't it have started to pump oil? Then, we put in a new pump, set all the timing back, and now the freakin car won't start yet again! Oh, and it overheats almost instantly (or its just a fault gauge, b/c it goes to operating temp on the gauge almost instantly)
OMG this thing is really making me hate KAs/240s! Not to mention my boyfriend's car won't start either...
