help safc wiring into s14
xdabsx
Car: 96 240sx/92 240sx coupe/94 240sx vert/95 240sx/93 240sx hatch
can anyone tell me which wires go where i know the black and brown are ground wires and have to go 1cm away from each other but i cant find any other info i got a s14sr20det WC ecu in a 96 240sx
SpeedRacer1
Car: 1990 240SX, G35
Go to this link and use page 6, 25, and 28 to do the install. Use diagram N-4a for your ECU. This manual is for the AFC NEO but the wire colors are the same as the SAFC and SAFC II. Though if you have the SAFC II let me know and I will show you where the knock sensor wire goes.
http://www.apexi-usa.com/pdfWiring/13.pdf
drftsx
Car: 90 240sx(sr)
all you do is find the pin out on the wc ecu and go to apexi website and find what the colors of the wires are for match it up and hook it together.
xdabsx
thanks speedracer
