DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Wed Aug 31, 2005 12:29 pm
okay, i just completed this exact thing on a 92 automatic, so i'm gonna point you through everything you gotta do.
You need: S14 head, and block. S13 intake manifold and exhaust manifold.
all the sensors you need are on your S13 manifolds. You can use the S14 oil pressure sensor and knock sensor, as they are already on the block.
If you use the S13 AC compressor you also HAVE to use the S13 AC bracket. The S14 bracket only attaches to the top two holes, and it makes the AC sit at an angle that makes driving it with a belt about impossible. The PS brackets are the same, the alternator bracket is the same.
If you use an S14 alternator you have to slightly modify (aka drill) the large ground wire, but the other connections are the same and it works.
I was trying to trace vacuum lines to see exactly how similar the S13 and S14 intake manifolds are, but then i got lost and just bolted up the S13 one. The S14 is better for high end, but its going to be more work to make this work, so just save it for a rainy day (ITBs).
I'm pretty sure the S14 exhaust manifold doesnt even bolt up to the S13 downpipe, and OBD1 and OBD2 S14 KA's both have different and wrong o2 sensors.
I'm having a hard timing remembering if i forgot something, but i'm pretty sure this is it.
so to recap:Use your complete S14 head and blockUse your complete S13 intake mani and exhaust maniPick the right AC bracket (if applicable)Depending on the alternator,a tiny tiny modification is necessaryI just grabbed a starter off my floor, don't know if its S13 or S14, so i dont know if it matters
If you get to it, try 248/232, have fun
