help, s13manual to s14auto COMPLETE swap
klingbiel1337
Car: 1943 240sx
Hello, this is my first post on this site, so Im hoping to get some answers that i havent been able to find anywhere.
Firstly here is my situation. I have both a s13(1993, 5speed stock ka dohc) then I also have a bone picked s14 (1995 was originally auto) the s14 has the harness pulled, motor pulled trans etc. its litterally just the shell nothing else. I took the stock harness,motor,trans drive train etc from the s13 and put it into the s14. The harness has been ran, the motor is mounted and everything but now here the problem is encountered.
1- the fuel pump plug on the harness from the s13 is not the same plug as the s14's fuel pump
2- the auto ignition locking cylinder is still in the car and it plugs into the correct parts on the harness but the wires in each pin dont match up.
and a few others but these are the most current and in the way issues. has anyone done or seen a swap like this? I know some of the s13 parts are swap able but im pretty much looking to see if im over looking some parts or if im missing anything. :woot:
