Help!! S13 with RB25DET setup Dakota SGI-5 with uk 200sx(CA18DET) Speedometer
alecuba16
Car: 90' DOHC ZC TURBO CRX, S13 With RB25DET
Hello!!
I have problems to setup the Dakota digital SGI-5 to convert the rb25det gearbox signal (speedometer) to my 200sx (ca18det oem engine) dash.
Can you help me to setup the Dakota??
When i ran the signal led flash intermittently as is receiving signal, but i tested on all outputs (channel 1 to 5) and no works.
I connected one straight cable from speed sensor (have 2green wires) to sgi INPUT, and continued it with SGI OUT 1 to subarness loom.
That's right?
Thanks
PD: Sorry my english
ninety1two40
Car: 1991 240sx SE
I've been running this unit with perfect results. However I'm using the RB25 with the 240sx, KA24DE cluster. The setup is pretty simple, make sure you have the dip switches setup correctly. Basically all that the flashing LED means when your driving is that the SGI-5 is receiving the speed sensor signal. I would pull the cluster and make sure you have the correct wire going from SGI-5's output to the speedometer input.
