help s13 with bad wheel hop
byroll01
Car: My Wife Danielle,Autox,PS2
I just installed new KYB/Eibach sportlines in my S13. Also just put on my Falken Azenis(205/50-15). I thought this would get rid of my wheel hop on hard acceleration but it's just as bad. The car is prety old(146000miles) so I may need to start replacing bushing too.any help would be great.
thanksbyron
Dori Dori
Car: Cars of course
What do you have for power?
240_Keyy
Car: '90 240 Fastback
wheel hop is caused by crappy subframe bushings, either replace them or get inserts.
Exar-Kun
Car: 2005 350Z
"wheel hop is caused by crappy subframe bushings" this is true to a point, its actually caused by the "grip-spin-grip" problem, which can be caused by subframe bushings, lack of power and a tire thats juuuuust sticky enough to grip, a differential problem, and other things.
my car has wheel hop, too, after checking a few things, I've dtermined it subfram bushing related, but I think my tires have a lot to do with it.-chet
byroll01
power is pretty much stock.
Maybe I'll try the subframe bushings.
240_keyy--- where did you get your bushings and how much?
thanksbyron
240_Keyy
I got mine from CTC Motorsports in Dallas for $190, they have to special order them from Japan. You might be able to find some Kazama ones for about $120 if you look for them long enough.
