SpeedRacer1 wrote:To be honost, if your wiring harness didnt come with ABS lines and the ECU wasnt programmed for ABS use then you might have to just not use it. Im not sure wether your harness was mode for ABS use but if it was then you should be able to locate the wires on the harness and splice them.
I got the S13 with a complete un-cut engine harness. I don't believe there were any connectors resembling ABS.
As for the ABS ECU on my S14 chassis...it appears to be 1-piece with the ABS Modulator unit, I'm not sure...but I think it operates independently from the Engine ECU?
