N/A Q45 »
https://forums.nicoclub.com/n-a-q45-u212067.html
Wed Apr 10, 2013 8:23 am
The stock wires can and do corrode/ oxidize and you can't tell just by looking at them, I replaced most of mine for the starter, grounds and charging system because of this and a few other reason's.
You can test you battery and alt yourself, leave the battery unhooked test its voltage before you unhook it overnight and test the voltage it has after sitting for atleast 8hrs should be around 12-12.6v then if that the voltage stays within that the battery is more then likely A okay. Hook it back up, run car till it is warmmed up so everything is up to temp and working the way it should, let the car idle and check the voltage at the battery onec with no load (every thing in the car is off) should be 14-14.7ish volts then turn everything on (lights, heater on full, rear defrost ect) if it drops to less then 12.5 there's a problem in the charging system ( alt or wires/connection)
