HELP!!! S13 CAM SWAP INTO S14 PROBLEMS!!! HELP!!!
sunnys14
Car: S14
HELP! i just swapped an intake and exhaust cam from a 92 s13 into my 95 s14. while the cams were all out, i compared both intake and exhaust cams from each car. i set them aside each other, intake to intake and exhaust to exhaust cam. there was NO visible difference at all on the cams from each other both intake and exhaust . i thought s13 cams had higher duration meaning the lobes should be tilted slighty different from the s14 cams.
but anyway, after getting confused, i put the s13 cams into my car (and yes i didnt get them mixed up!). green intake cam from s13 and orange exhaust cam from s13. when i pulled the cam sprockets off, i wire tied them together to the timing chains while marking them with some paint to make sure i didnt forget how the sprockets lined up at. while taking off the cams, i accidently hit the wire tie and made the sprockets fall off from the chain! well thankfully i marked the sprockets with the paint so i just took the sprockets out and put the cams in, then i put the sprockets back onto the cams and chain.
after putting everything back, cleaning up, i decided to crank my car to see how the cams would run! this is what scared me: the car started for a split second and had a VERY VERY low idle, which was around 500 rpm or so. it started for about 5 seconds then it died . i was confused on why this happened! so i tried to crank the car over again and it would crank but would turn over and start! does anyone know what my problem is??? it was getting real late and too cold and dark to see so i just called it a night and hopefully try again tomorrow!
does anyone think i messed up the timing by not setting the car to TDC correctly or was it because i took out the cam sprockets? i set the car to TDC by putting some tissue into the #1 cyl with the spark plug removed and all the spark plug wires removed from all the others. i cranked the motor till the first cam lobes were pointing away from the center of the engine and the distributor rotor was pointing at the #1 mark. i really need this car for work and this CAM swap project has turned into a disaster for me! HELP PLEASE!!!
NateDogg
Tissues are for blowing noses and wiping butts, not for setting the motor at TDC.
Maybe that's your problem.
sunnys14
Car: S14
didnt i set the motor at tdc by cranking the motor till the front cam lobes are pointing away from each other and the dist. rotor is pointing at #1? even if i didnt set it at tdc, what is the worst that could happen if i just swapped the cams? i used the tissue so i kno wen the #1 cyl is firing which would blow the tissue out of the cyl (compression stroke?). HELP PLEASE
TheOne
Car: 93 240sx FB
first check compression as the worst thing that could've happened was the valves got bent by the pistons(tho i don't think so).just try to adjust the timing again.
sunnys14
Car: S14
sorry to be such a nub but, how do i check compression?
sunnys14
Car: S14
also, how do i adjust timing? my crankshaft pulley isnt original because i got a unorthodox racing one so the pulley isnt set with the timing marks!
Red coupe
Car: 92 Nissan 240sx Coupe
I have absolutly no I dea what you did with the tissue...If you marked the cam and sproket with paint and then match that back up I would think that would be fine, but is the cams and crank in time with each other? best way to do that would be set the crank to TDC, then set the cam one TDC, there should be a mark on the cam some were to show you when the cam is on TDC, line the pin on the cam up with the colord link on the chain( one link should be a diff color in pick Ive seen it was a different shade of grey) after getting the chain on turn the engin by hand a few times and stop with the crank at TDC, and check to see if the cams are as well. (Ive never done on nissan engin only on toyota but there was a small notch on the block and on the sproket on the crank, and something similar for the cams), if your pully has no marks and you have no way of establishing TDC for the crank a rough esstimate can be made by putting something (like a dowl or something simmilar) in the spark plug hole so that it rests on the piston top and stick out of the engin so you can see the movement of the piston, watch the stick and when it reaches the top of its travel mark the pully, continue turning and when it begin to go down mark again this marks the beging and end of the piston dwell at TDC, so the crank is straigh up right inbetween the two marks, mark the center point and use this for a rough timing estimate....
sunnys14
Car: S14
i dont think i set the car to TDC when i first removed the stock cams. now that i put the new ones in, i set the it to TDC, then installed the cams like how the s13 cam sticky faq shows. i put everything back together, then wen i turn the engine, all i hear is a whirring noise and the exhaust pops for a bit. then it continues whirring, not even trying to start. i am getting spark across all 4 plugs. its just the whirring noise and the car isnt even trying to turn over! will the car not start if both cams were off by 1 notch? if so can someone please tell me? ive been working on this car for 4 days straight and i cant seem to find out what is wrong!!!! please help!!!
NateDogg
Yes the car will start and run fine even with the cams off by one notch (don't ask why I know).just read over the manual but better yet go to the jimwolftechnology.com tech install of cams into a KA24DE. They have a really good diagram of how its supposed to look.
sunnys14
Car: S14
i did exactly what the jim wolf website says AFTER i messed up. so correcting everything SHOULD make it start again. but now its not starting. i have no idea why its not starting.
sunnys14
Car: S14
i just checked my compression last night. took out the spark plugs, put the compression tester in each of the holes and i got 0 psi across all 4 cylinders! does this mean i have bent valves??? i sure hope i dont!
Red coupe
did start the engin with the timeing off the first time you had it messed up? if you did it could be bad news...
sunnys14
Car: S14
i started the engine the first time and the car had very low idle (around 400 rpm) then it just died. the car atleast cranked when i started it the first time. so i adjusted the cams now the car wont even crank. the chain just spins and it wont crank at all. i reset everything back to TDC #1 and now its still not cranking at all... i dont know what is going on.
chandler
Car: 91 civic hb & 96 S14
so if you have 2 s13 exhaust cams they are both orange stripes?
sunnys14
Car: S14
yay! even more problems arise! i managed to break the 91 intake cam when trying to adjust it. so now im running a 248 intake cam (rotated 4 teeth) and a 232 exhaust cam. same thing happens! the car wont try to start. 0 compression even when everything is set at TDC. i read that your car wont start if the ground wire (connected to the front O2 sensor by the brake master cyl) isnt pulled into the engine block. is that right? well i hope someone can help me soon because this has turned into a complete disaster for me!
chandler
man that blows, is it not cranking or just not starting?are you checking comp with the throttle wide open?thats how we were taught at school, and are you checking comp when cranging?
sunnys14
Car: S14
checked compression with gas pedal to the floor. 0 psi across all 4 cylinders. i think the valves arent closing. either cuz i didnt line up the cams correctly after 4564632634 times of trying or theyre bent up. i have no idea
chandler
thats cranking right? sound like ya bent all ya valves man, sorry to hear that. you are cranking the engine while checking right, not trying to beat a dead horse , just checking
sunnys14
Car: S14
yes i cranked my engine while cranking still nothing
chandler
yep, sounds liek bent valves man,only way to tell for sure, is to pull the head flip it over with out cams in and pour water into the combustion chamber and see if it leaks
sunnys14
Car: S14
ok, i got my motor checked and it turns out that i bent ALL the valves on my intake side. i blew air into the #1 cyl and it was all leaking through my intake. so i guess i have to pull the head and replace them now.
NateDogg
Sorry to hear that. I did that once. Hopefully they aren't bent so bad they're beyond repair.
sunnys14
Car: S14
all i know is that theyre noticably not touching the cams anymore. you think that is repairable?
chandler
its repairable, but you need all new valves, Man that just blows
sunnys14
Car: S14
the price of valves and machining them is almost the same as getting a used block with valves... haha
