T-rev »
https://forums.nicoclub.com/t-rev-u68340.html
Mon Jun 23, 2008 7:53 pm
I got the same thing with my motor. I replaced the water pump because it looked pretty knarly. Also I rigged up a garden hose to flush out as much of the crud as possible. Aluminum block means it doesnt stick around.
I just purged my coolant system about once a week for the first month (use cheapo antifreeze 50/50 water). Then when I saw no more crumblies in there I filled it up again with the good stuff, honda anti freeze, distilled water, water wetter if you like, etc you know the drill.
