kapower06 wrote:I know this isn't my forum so to speak. But are you still getting your cas code? If so have you tried fixing the wiring? also have you swapped yours onto a running SR to make sure the one you have is good? If so and the wiring checks out good, you could have burnt the ecu curcuit for the cas.
Sorry I forgot to mention this.. yes the CAS code is gone. I unplugged the batt for a few hours and when I hooked everything back up the code 11 was gone. I even swapped ecu's when I had the code and it didn't go away. It seems to be gone now.
Something I was wondering was that is the CAS was way off would it throw a code?
This was a brand new wiring harness I used. I don't have another SR to test it with but I plan on pulling it out and looking it over just in case. The wiring is not very difficult but I could have ****ed something up. Although everything seems to work aside from the car not starting. Fuel, Compression, Spark, etc
