That one's pretty normal. For example, 2008's actually reached dealers in 2007.sorceress wrote:it was built in 91 but registered as a 92
Shouldn't your friend be the one on here asking, since they own the Q?sorceress wrote:yea world wide and what is jdmreason for #'s is the friend wants to qualify for collector plate status
First question is how many were sold in the US? Take 10% of that number as Dennis mentioned earlier. Then add 85% of Japanese sales (If we were to assume that 85% of the Q45s and Presidents were both sold as Active models in Japan.) Then, the next question would be how many Q45s were sold in other markets? I always see many more Presidents for sale in Japan than Q45s which makes me wonder how rare these cars must be in other parts of the world.maxnix wrote:I have always wondered how many G50 were sold, but before I successfully bid on a 2001 G50 press kit, I never knew.
Forthwith are the sales figures by year by model:
1989 1,1081990 13,9611991 14,7071992 12,3161993 12,4111994 11,4191995 7,8031996 5,896
TOTAL 79,621
Does your friend who own the Q45 Active live in Canada?sorceress wrote:one friend lives in canda so that why they looking for #'stwo cannot get online except when they come to visit me so i do all the researchwhen it come to online stuff
I have looked at lots of 1996 model q45`s , and never seen a VIN above 4150 as the last 4 digits {1996 models began with 0001 as the last 4 digits of the VIN}, so I would assume less than 4200 1996 Q models were built.Q45tech wrote:Unfortunately those were sales number in a calender year not Model [year]numbers sold.
All one can derive is that the 90-94 models sold about equal numbers and the collapse occured with 95 model since 97 was first sold in 96.
No TCS button or no N/H switch? Or both?sorceress wrote:.....edit: just called the friend and they say no button
$300 should cover my round trip plane ticket to repair your antenna mast for you and I'll supply the mast.sorceress wrote:btw where can u go to replace the radio antenna in the lower mainland it no goes down on their car and was told it would be $300 to fix
Those are US annual sales number, not distinguisahble by model year.sorceress wrote:yes he does lino and thank you so much for the numbers
Read Tangalora's excellent post in IOM forum.sorceress wrote:btw where can u go to replace the radio antenna in the lower mainland it no goes down on their car and was told it would be $300 to fix
I heard it was 20 years in NJ so I'm waiting. But I'm not too clear on the rules.superuber wrote:In Pa you can get classic plates at 15 years. But it has to be all original.Wonder if I qualify? I'll find out in two years. Once your car is made a classic no registration fee forever!
You are right, no ACTIVE cars in Canada, except for me . (My car is a US car that I imported.)GseaQ wrote:TCS (traction control) is pretty common in the northern market. I don't think the active model "a" was ever offered in Canada.
You are right again. I bought my antenna mast from Joe at Infiniti of Scottsdale (IOS) for $35.08. Unfortunately, my antenna still doesn't go down all the way. I tried everything, including taking apart the motor. I think I may need a new motor. Here are some pics:GseaQ wrote:The antenna mast cost is $135 at Canadian Infiniti dealers (yes, just the mast!) versus $35 (I think) at IOS or $25 on eBay.
Cut a few inches of the plastic leg off and it should retract to the right level (flush).lino wrote:......Unfortunately, my new antenna still doesn't go down all the way. I tried everything, including taking apart the motor......
I bought mine off ebay and I remember reading that that you trim the leg if it doesn't go down all the way.lino wrote:At first, it would stop about 3 inches too high, so what you are saying makes sense. Why would it be too long considering it is an oem part?
Are the ones from ebay that you're talking about like this one?goody94q45 wrote:
Seriously, you can buy the mast off Ebay for $25 shipped to your door and install it yourself. It won't take 10 minutes and you don't need any tools, just a 2nd person to turn the head unit on. Go to Q45.org in the Tech Help section for step-by-step instructions or search here with the keywords antenna mast.
That looks like the one. The plastic teeth on the tail strip out, the mast finds a dead spot and won't fully retract.ddrumman wrote:Are the ones from ebay that you're talking about like this one?
I didn't say trim the head, just the tail.maxnix wrote:OEM shouldn't need a trim. What, you think it is Jewish?
I took the thing apart 3 times and I could have sworn there was no little pieces. My old tail broke into 2 pieces. It appeared to be a clean break. I spent hours trying to get it to work. I ended up figuring out a "trick". What I did was turn off the radio and wait for the antenna to retract. Once it stopped, there would still be a few inches that did not fully retract. I would then turn on the radio and immediately turn it off and the antenna would go all the way down. Sometimes I had to do the trick twice to get it to fully retract. Now, that trick doesn't work. It just stops short.goody94q45 wrote:
Lino- are you sure you got out any remaining tail that might have broken off in the motor body ?
I have the identical situation with the '92 (new mast from IOS), but the "trick" still works. My service guy says the motor is getting weak.lino wrote:
