Help replacing Y33 antenna base
MAX_POWERS
I bought a new antenna nut, base and an antenna socket set. The socket set I bought does not have the right size socket. Where can I get the right size socket?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Well, a SnapOn or MAC jobber for sure, maybe Sears in a pinch.
What size and where have you looked?
Modified by maxnix at 9:20 AM 1/27/2008
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
MAX_POWERS wrote:I bought a new antenna nut, base and an antenna socket set. The socket set I bought does not have the right size socket. Where can I get the right size socket?
The one that i just removed doesn't have sides like a regular "nut." It is a circle with 4 slots cut into it, I used a screwdriver and hammer to remove one, but damaged it slightly. If you've got a new one then you can probably use this method if you grease the threads a little and are very careful.
MAX_POWERS
The Snap On socket is the same socket I already have, but more expensive. The Mac socket set is just a Lisle socket set, also more expensive. I am going to look in to the Lisle socket set to see what sizes are avaliable.
vvvvv This is the socket set I have. vvvvvv
vvvvv Here is the Mac / Lisle set. vvvvvv
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
MAX_POWERS wrote:The Snap On socket is the same socket I already have, but more expensive.
Really? I thought SnapOn manufactured all their sockets and did not buy 3rd party products.
