08AltimaCoupe12790 wrote:ok, i have a 98 Altima SE in addition to my 08 Coupe. replacing the light is VERY simple. if you raise the hood you will see that there is a single phillips head screw holding the bracket in place. after removing it, the light will be loose in the housing. pull it towards the front of the car and if needed, tap lightly on the back so it will pop out. thats it! just make sure when you re-install one that it is lined up corectly before putting the screw in.
Thanks for the help! Although - as I said - the metal bracket that holds the light in there was broken and sheared off during the impact so that is not the issue. That was the first thing we saw when we popped the hood. The light IS very loose in the housing - but I'm telling you we have taken huge screwdrivers, crowbars, hands, EVERYTHING to this light to try and get it to "pop out" as everybody claims it should. No dice. I have pulled on the light so hard that it almost literally shattered the lens before the stupid thing came out of the post stud it is stuck in. Why does my car have to typically be the one which is different and DIFFICULT? LOL.
Anyways - I ordered the part yesterday - a grand total of $24.01 so that doesn't really bother me. The light still works and obviously it's better stuck IN there rather than having it hanging out down to the ground attached by only the bulb wiring, ROFL. So - we will put your advice into practice when the new light arrives. Let's hope that sucker pops out with a bit of persuasion!!!
Cheers guys!
TT
P.S. - I'm a GAL! Not a GUY! LOL..............
